Thinking of changing CK print head on my Roland SP300i
Ravisteam
Re: Thinking of changing CK print head on my Roland SP300i
Post by Ravisteam »
Hi guys ..Can we change the print head with out a tech ??..Is it doable ?...my sp300i need a dx4 head as the black is not perfect ..Just thought to do it my self ..Any advice ?
Andrew
Post by Andrew »
Everything is doable, more a case of are you capable. I have got the larger version of what you have and I am able with fixing things and wouldn't fancy changing that head. Too many things to not get right on a big piece of kit. Have changed the pinch rollers and a couple of other things but in hindsight I should have got someone in who will get it like new. Depends how essential it is really as to whether you don't mind taking the risk. Sure there will be youtube help out there as well if you wanted to try. Whatever timescale they give allocate twice as much and work out what your time is worth to the business.
I echo what Andrew says, the head on mine could probably do with changing but as the actual unit is £1500 +VAT (its the white and metallic head - Epson DX6) if I screw up then that's a lot of money down the drain...
Ravisteam
Post by Ravisteam »
I managed to change a head and I think its successful , I couldn't find a techie that could fix it asap so I did it my self .I was bit nervous but just gave it a go .Took about 2-3 hrs including head alignments so not too bad as these days business a bit quite too lol, Got a great support from Scotty:smile: too ..Its firing all the nozzles now :biggrin:..I think it needs a very small adjustment you can only see on the really small fonts but will deal with it later ...
vB_ID:5596
vB_ID:5596
scotty44
Post by scotty44 »
Nice one Ravi, glad you got it sorted :cool:
Andrew
Post by Andrew »
Good job. You can come and do mine if you got spare time ;-)
Ravisteam
Post by Ravisteam »
Andrew;136954 wrote:Good job. You can come and do mine if you got spare time ;-)
:confused:
rabb
Post by rabb »
I replaced my DX7 printhead in my BN-20. Took a wild punt and bought one from China along with new original dampers for £1200. Took me an hour or so to do it.
It's like a new printer again. The only thing I couldn't do was enter the head rank supplied with the new head but the print quality I'm getting is top notch with my own custom ICC profile.
scotty44
Post by scotty44 »
rabb;142780 wrote:I replaced my DX7 printhead in my BN-20. Took a wild punt and bought one from China along with new original dampers for £1200. Took me an hour or so to do it.
Got a link mate?
