Hi all
Looking for help with above printer.
Got it about a year ago & not don't anything with it
Till recently got new ink & got A sub paper.
It's printing but the ink isn't transferring on
To anything we try & sublimate.
Any help would be amazing
Epson WF 7310
Islandgifts.
Re: Epson WF 7310
Are you using 'DYE SUBLIMATION' ink or regular 'DYE BASED' printer ink? Big difference.
Islandgifts.
Re: Epson WF 7310
Hi sorry for my ignorance. It's the ink that was supplied with the printer. What is the difference & which is the best ?pw66;153612 wrote:Are you using 'DYE SUBLIMATION' ink or regular 'DYE BASED' printer ink? Big difference.
Re: Epson WF 7310
Do you mean the original Epson start up cartridges that came with the printer? Those are just regular printing carts and will not sublimate.Islandgifts.;153625 wrote:Hi sorry for my ignorance. It's the ink that was supplied with the printer. What is the difference & which is the best ?
You need specialist Dye Sublimation ink to sublimate. Sublimation ink releases the colours when heat pressed, regular ink doesn't.
I don't think our usual 'favorite' supplier stocks anything for the 7310 so I got mine from Ink Express.
You will need these and you will be up and running -
https://www.inkexpress.co.uk/product/co ... set-empty/
https://www.inkexpress.co.uk/product/in ... c-profile/
Islandgifts.
Re: Epson WF 7310
[ATTACH=CONFIG]7323[/ATTACH
This is the ink we got & the refillable cartridges with the chip.
- vB_ID:7323
- PXL_20240304_135232997.jpg (76.67 KiB) Viewed 332 times
Re: Epson WF 7310
It doesn't say sublimation on the label so it is a reasonable assumption that it is ordinary dye based printer ink.Islandgifts.;153645 wrote:[ATTACH=CONFIG]7323[/ATTACH
You need to syringe the ink ouit of the carts, buy some sublimation ink and start again. Maybe buy some nozzle rocket to clean the heads or just run a few dozen test sheets on cheap copier paper to use the last of the old ink.
Or just buy a second set of carts.
Islandgifts.
