Epson WF 7310
Islandgifts.
Re: Epson WF 7310
Post by Islandgifts. »
Hi all
Looking for help with above printer.
Got it about a year ago & not don't anything with it
Till recently got new ink & got A sub paper.
It's printing but the ink isn't transferring on
To anything we try & sublimate.
Any help would be amazing
pw66
Re: Epson WF 7310
Post by pw66 »
Are you using 'DYE SUBLIMATION' ink or regular 'DYE BASED' printer ink? Big difference.
Islandgifts.
Re: Epson WF 7310
pw66;153612 wrote:Are you using 'DYE SUBLIMATION' ink or regular 'DYE BASED' printer ink? Big difference.
Hi sorry for my ignorance. It's the ink that was supplied with the printer. What is the difference & which is the best ?
pw66
Re: Epson WF 7310
Post by pw66 »
Islandgifts.;153625 wrote:Hi sorry for my ignorance. It's the ink that was supplied with the printer. What is the difference & which is the best ?
Do you mean the original Epson start up cartridges that came with the printer? Those are just regular printing carts and will not sublimate.
You need specialist Dye Sublimation ink to sublimate. Sublimation ink releases the colours when heat pressed, regular ink doesn't.
I don't think our usual 'favorite' supplier stocks anything for the 7310 so I got mine from Ink Express.
You will need these and you will be up and running -
https://www.inkexpress.co.uk/product/co ... set-empty/
https://www.inkexpress.co.uk/product/in ... c-profile/
Islandgifts.
Re: Epson WF 7310
[ATTACH=CONFIG]7323[/ATTACH
This is the ink we got & the refillable cartridges with the chip.
vB_ID:7323
vB_ID:7323
pw66
Re: Epson WF 7310
Post by pw66 »
Islandgifts.;153645 wrote:[ATTACH=CONFIG]7323[/ATTACH
It doesn't say sublimation on the label so it is a reasonable assumption that it is ordinary dye based printer ink.
You need to syringe the ink ouit of the carts, buy some sublimation ink and start again. Maybe buy some nozzle rocket to clean the heads or just run a few dozen test sheets on cheap copier paper to use the last of the old ink.
Or just buy a second set of carts.
Islandgifts.
Re: Epson WF 7310
Ok thanks very much for your help hope i can be of help to you sometime.
Colin
