Request: 12oz Latte Mug PSD file with Smart Object Warp
Offer your services/products to other members here or post your requests
Chad
Re: Request: 12oz Latte Mug PSD file with Smart Object Warp
Post by Chad »
I bought a handful of 12oz Latte Mugs to have a play with, and tried my best to make a PSD file where the design follows the shape of the mug without distorting once printed. The design I made is fairly good and gives me 100% coverage (Attached here if you want to download it) The top half of a design seems to be stretched quite a bit but I'd like something that gives a perfect representation when printed. If anyone could share, it would be mug appreciated!
We tend to buy objects made by this lady selling on etsy if that helps.
Etsy: https://www.etsy.com/uk/listing/5230657 ... hare_v4_lx
Moved thread into Member to Member Offers/Requests section.
Post by GoonerGary »
Chad;153627 wrote:I bought a handful of 12oz Latte Mugs to have a play with, and tried my best to make a PSD file where the design follows the shape of the mug without distorting once printed. The design I made is fairly good and gives me 100% coverage (Attached here if you want to download it) The top half of a design seems to be stretched quite a bit but I'd like something that gives a perfect representation when printed. If anyone could share, it would be mug appreciated!
How many degrees is your arc?
Chad
Post by Chad »
UK Printed Mugs;153628 wrote:We tend to buy objects made by this lady selling on etsy if that helps.
Thanks, but does that include a printable template too?
Depending upon how deep you want to go into this, you can use Inkscape (Free) to produce unrolled truncated cones of any size with this extension.
I've just tried it out with some made-up settings off the top of my head and this is what it produces ...
[ATTACH=CONFIG]7311[/ATTACH]
[ATTACH=CONFIG]7310[/ATTACH]
[ATTACH=CONFIG]7309[/ATTACH]
Checking the 'Dimensions' checkbox in the dialogue adds dimensions to the drawing.
[ATTACH=CONFIG]7312[/ATTACH]
Once finished, you can easily save and import into Photoshop or whatever for further processing and image warping.
vB_ID:7312
vB_ID:7312
vB_ID:7311
vB_ID:7311
vB_ID:7310
vB_ID:7310
vB_ID:7309
vB_ID:7309
Chad
Post by Chad »
Thanks for your efforts, however the issue isn't the cone shape (which I have created myself) It's how the image is warped around the arch template, to accurately be represented on the printed mug.
As you can see below, the embedded file is roughly half foreground and half sky, with a straight horizon.
[ATTACH=CONFIG]7314[/ATTACH]
Once embedded into the smart object, the horizon appears lower, with the sky taking up 3/5ths of the image.
[ATTACH=CONFIG]7315[/ATTACH]
Once printed onto the mug, the horizon is still not in the centre, and it swoops upwards on the right hand side. I'm looking for a PSD file that will accurately warp an image and retain it's form.
[ATTACH=CONFIG]7316[/ATTACH]
[ATTACH=CONFIG]7317[/ATTACH]
vB_ID:7317
vB_ID:7317
IMG_4716 copy.jpg (75.32 KiB) Viewed 3351 times
vB_ID:7316
vB_ID:7316
IMG_4716w copy.jpg (77.6 KiB) Viewed 3351 times
vB_ID:7315
vB_ID:7315
Screenshot 2024-03-02 at 13.00.03.jpg (19.48 KiB) Viewed 3351 times
vB_ID:7314
vB_ID:7314
The Milky Way Over Mount Bay White Mug.jpg (96.86 KiB) Viewed 3351 times
vB_ID:7313
vB_ID:7313
After placing the image into the Smart Object, did you then use the Warp Tool to warp the Smart Object layer?
A bit like this ...
[ATTACH=CONFIG]7319[/ATTACH]
[ATTACH=CONFIG]7318[/ATTACH]
You'll notice that the horizon line stays at a constant height over the whole of the mug wrap and should thus be centred around the mug when pressed.
vB_ID:7319
vB_ID:7319
vB_ID:7318
vB_ID:7318
Chad
Post by Chad »
I don't think so, I'm not sure how you managed to do that
