Mugs - Alternative print methods
Help in finding new products.
Re: Mugs - Alternative print methods
Looking at alternative print methods for mugs and other items.
Attached image for reference. Not sure of this is water decal transfer.
Appreciate guidance on suppliers or preferably techniques used.
[ATTACH=CONFIG]7426[/ATTACH]
Example image.
vB_ID:7426
vB_ID:7426
GoldRapt
Been thanked: 8 times
Post by GoldRapt »
Water slide transfers, especially those designed for ceramics, need to be kiln fired after application to properly fuse them onto the ceramic piece and make them permanent; essentially "baking" the decal onto the surface with heat from the kiln. Do you have one?
regards
Tony
-launching july/august 2026
Yes appreciate we would need a kiln, would be looking to get one.
pw66
Post by pw66 »
UV DTF? You already have the presses. Order in by the linear metre to save the £20k for a machine.
