Looking at alternative print methods for mugs and other items.
Attached image for reference. Not sure of this is water decal transfer.
Appreciate guidance on suppliers or preferably techniques used.
Mugs - Alternative print methods
Re: Mugs - Alternative print methods
[ATTACH=CONFIG]7426[/ATTACH]
Example image.
Example image.
- vB_ID:7426
- IMG_20250216_202106.jpg (87 KiB) Viewed 3028 times
Water slide transfers, especially those designed for ceramics, need to be kiln fired after application to properly fuse them onto the ceramic piece and make them permanent; essentially "baking" the decal onto the surface with heat from the kiln. Do you have one?
Yes appreciate we would need a kiln, would be looking to get one.
UV DTF? You already have the presses. Order in by the linear metre to save the £20k for a machine.
