I've been asked if I can find some round coasters which are 15cm diameter. All the ones |I can find are 9.5 or 10. Anybody any ideas ?
Dave
Circular Coasters
Re: Circular Coasters
Only one that springs to mind is a glass coaster as seen here:
http://www.westcoastprinting.eu/coasters.htm
Not sure if this particular on is available in the UK.
Can probably get these made for you from the same material as the 90mm square ones. How many are you interested in - might need to be 50+? I can get a quote for you.
Would be great if you could Martin, The customer is enquiring about 2 lots of 28, so 50+ would be good
