crafrobo ejecting paper
Re: crafrobo ejecting paper
Hi all i have problems with my craftrobo cc330-20......................all was fine then i went to cut a printed image and it ejects the page, It reads the cut lines ok then when i press cut it ejects the paper any ideas?
i have removed software and reinstalled but the same thing happens:mad:
cheers Nigel
cheers Nigel
If no one else has an answer, you can try the Graphtec "Tech support team". Brian 01978 666700.
Shirt Printing Design and Culture teesandhoodies.com
Nigel - are you selecting 'load with carrier' as an option and making sure the paper is on a carrier?
Doing this makes sure the paper is taken in futher to allow the eye to read the registration marks.
Hi Adam, yep paper's on the carrier.
The machine reads the registration marks ok then when i press ok to cut it pushes the paper forward and then says reload !!!!
strange
strange
Hi Nigel - not wanting to send you away from this fine forum in anyway but there is a forum called UK Scrappers that have hundreds of Robo users - you may see your answer there ....................... but if you do get an answer can you let us know just in case anyone else experiences the same problem.
what a plonker, i just realised i made 2 copies of a document 1 with cutting lines 1 without and the one i keep re-loading doesn't have cutting lines .NIGELG;29825 wrote:Hi all i have problems with my craftrobo cc330-20......................all was fine then i went to cut a printed image and it ejects the page, It reads the cut lines ok then when i press cut it ejects the paper any ideas?
cheers Nigel
i put a black boarder around it and mentally i think it was the cutting line ..............................god i'm so embarrassed
thanks for your feed back
note:to self items to be cut need a cutting line xxxxxxxxx
glad all is sorted - it's also good when you know it's human error and not the machines at fault
