crafrobo ejecting paper
NIGELG
Re: crafrobo ejecting paper
Post by NIGELG »
Hi all i have problems with my craftrobo cc330-20......................all was fine then i went to cut a printed image and it ejects the page, It reads the cut lines ok then when i press cut it ejects the paper any ideas?
i have removed software and reinstalled but the same thing happens:mad:
cheers Nigel
P4UL
Post by P4UL »
If no one else has an answer, you can try the Graphtec "Tech support team". Brian 01978 666700.
AdamB
Post by AdamB »
Nigel - are you selecting 'load with carrier' as an option and making sure the paper is on a carrier?
Doing this makes sure the paper is taken in futher to allow the eye to read the registration marks.
NIGELG
Post by NIGELG »
Hi Adam, yep paper's on the carrier.
The machine reads the registration marks ok then when i press ok to cut it pushes the paper forward and then says reload !!!!
strange
AdamB
Post by AdamB »
Hi Nigel - not wanting to send you away from this fine forum in anyway but there is a forum called UK Scrappers that have hundreds of Robo users - you may see your answer there ....................... but if you do get an answer can you let us know just in case anyone else experiences the same problem.
NIGELG
Post by NIGELG »
cheers mate will do
NIGELG
Post by NIGELG »
NIGELG;29825 wrote:Hi all i have problems with my craftrobo cc330-20......................all was fine then i went to cut a printed image and it ejects the page, It reads the cut lines ok then when i press cut it ejects the paper any ideas?
cheers Nigel
what a plonker, i just realised i made 2 copies of a document 1 with cutting lines 1 without and the one i keep re-loading doesn't have cutting lines .
i put a black boarder around it and mentally i think it was the cutting line ..............................god i'm so embarrassed
thanks for your feed back
note:to self items to be cut need a cutting line xxxxxxxxx
AdamB
Post by AdamB »
glad all is sorted - it's also good when you know it's human error and not the machines at fault ;-)
Users browsing this forum: Semrush [Bot] and 4 guests
