ICC Profile needed please
Sdj
Re: ICC Profile needed please
Post by Sdj »
I'm after a ICC profile for an Epson xp 212,
Cheers
An ICC profile is dependent not only on your printer model, but your inks.
Two different ink brands will exhibit different colour properties, so the ICCs for different inks are not interchangeable.
If your ink supplier cannot supply an ICC profile, then you will need to get a custom one made (about £25)
If your ink supplier says that you don't need one, (or something like "use Adobe 1998") then they are either lying or don't know what they're talking about, and you should consider finding a better supplier.
Sdj
Post by Sdj »
Paul.....
I'm trying to send you a message but your inbox is full.
Cant seem to turn the No color management off in CS5, any ideas?
[ATTACH=CONFIG]2662[/ATTACH]
vB_ID:2662
vB_ID:2662
15-04-2014 08-29-34.jpg (85.87 KiB) Viewed 349 times
Post by GoonerGary »
You need to download the Adobe Color Printer Utility.
GoonerGary;86757 wrote:You need to download the Adobe Color Printer Utility.
See here:
http://helpx.adobe.com/photoshop/kb/no- ... ssing.html
This prints the files from Paul without any colour management, but you will still need to make sure colour management is turned off in your printer driver, and make a note of any other settings you use (for the paper type and print quality) as the settings you have for the test prints will be the ones you need to use for your actual printing with the new ICC.
inbox clean! fire up!! :)
