Polyester Printing HELP!
Re: Polyester Printing HELP!
Evening guys help required I’m printing sublimation using Epson WF7210 using trupix paper and fotorite ink from ink express, every time I press at 190c for 60 seconds I get big shiney square scotch on the garment how can I overcome this?
- mrs maggot
the scorch marks you are getting can you post a photo, is it the same size mark every time ? what are you putting over your garment ie silicone paper ? or is it just the heatpress and the paper ?
ill try and post a photo, it’s the whole heat press square making it shiney, using paper and greaseproof sheetmrs maggot;139410 wrote:the scorch marks you are getting can you post a photo, is it the same size mark every time ? what are you putting over your garment ie silicone paper ? or is it just the heatpress and the paper ?
What garment are you using? What colour? What colour is the scorch mark.
Try backing off the time, temp, and pressure - experiment til you find a sweet spot
Is the outline the mark of the paper (if so make your paper bigger than the press or tear the edges to soften them from being sharp)
A look at how it is
- vB_ID:5831
- 9B4759C2-A80F-4F19-B2C5-D4DF9D99EE47.jpg (39.95 KiB) Viewed 342 times
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Is that printing a yellow tint to the paper?
So when you print does it print just the image and then spit the paper out.
Or does it continue for a while then spit the paper out?
Have you been printing hi-vis or bright coloured polyester?
Is your cover paper leaching something onto the fabric when pressed?
